How-To - Parking Sensors and Reverse Camera in e89
AnubisZed
Veteran
 Lincolnshire, UK
For those that were waiting, here is the How-To video on installing Parking Sensors and the Reversing Camera in an e89. Parts links are on the YouTube page.
Many thanks for you helpful video Dave.
I wish I had watched it before I spent this afternoon trying to install a rear camera which connects to my dash cam!
I managed to get the wire from the cam mounted on the rear view mirror to the boot of the car. I ended up going through the 'ski hatch'.
However I got stumped when it got to getting the wire to the number plate area, guessing (as in your great video) I may have to take the bumper off.
Can you think of a way/route I could get the wire to the number plate light from the boot without removing the bumper though please?IMG_4914.JPG
Also I need to get 2 wires for the sensor to goto the reverse light. Do you think I could splice them into the light cluster loom . If so do you know which 2 wires please ?IMG_4905.JPG
When I removed the battery cover I came across this loose wing nut IMG_4906.JPG
I am glad I found it as it could have possibly caused a short. I then had a look to see where it may have come from and eventually came across the 3 wing nuts underneath the tray where the roof lays on when open-sure enough, one was missing and the others were loose so it was a good job I came across this!
Incidentally, I have fitted this dashcam https://www.amazon.co.uk/gp/product/B07K1T4FT3/?tag=z4fo-21
I went for this as I wanted to 'hide' the dashcam plus it was easy to install. Power is currently coming from the lighter socket under the arm rest. I may hardwire it in to use the parking guard but am a bit apprehensive about the drain on the battery (only drive at weekends) plus tacking the dreaded fuse box access!!
Thanks again
Yoghurt/Mike
Yoghurt said:
Many thanks for you helpful video Dave. Thanks
Can you think of a way/route I could get the wire to the number plate light from the boot without removing the bumper though please? No, sorry it's not possible, you just cannot get access to it due to the large "lip" that goes forward from the lower part of the bumper.
Also I need to get 2 wires for the sensor to goto the reverse light. Do you think I could splice them into the light cluster loom . If so do you know which 2 wires please ? Wire them to the loom side, not the lamp side and you need the Brown for negative and the Black Blue for the positive
I am glad I found it as it could have possibly caused a short. I then had a look to see where it may have come from and eventually came across the 3 wing nuts underneath the tray where the roof lays on when open-sure enough, one was missing and the others were loose so it was a good job I came across this! That was lucky then!
I went for this as I wanted to 'hide' the dashcam plus it was easy to install. Power is currently coming from the lighter socket under the arm rest. I may hardwire it in to use the parking guard but am a bit apprehensive about the drain on the battery (only drive at weekends) plus tacking the dreaded fuse box access!! The Parking Guard that I have for mine has a battery drain protection built in, ie; it stops working once it hits the lower limit that you set, so it's perfectly safe
Thanks again
Yoghurt/Mike
Answers in red above :thumbsup:
