How to ignore indicator light voltage?
skmattwell
Active member
 London
The right indicator is hyperflashing despite all bulbs working fine. My zed won't pass it's MOT until it's fixed. I've replaced all of them and still no luck. Is there a way of coding with carly or ncexpert of ignoring the indicator voltage? And if so, anyone around NW London?
I'm heading to Bracknell Friday morning to sort an airbag issue. I have Scanner 1.4 which can turn off the checks.
Is there any way we can connect?
I will be there at 10am and need to be home by 5pm.
DM sent with my mobile number if I can help.
Cheers mate, replied to your dm!
In case anyone else has the same issue, I've now experienced this twice.
The fault is not in the indicators, it is a high resistance across one of the rear sidelight bulbs. Code out the checks to that and the indicators work properly again.
Would changing the rear sidelight bulbs help?
I've had similar quick flashing on my left indicators with all bulbs working.
Possibly yes. They all worked though. Could be the contacts on the light holder too. Knowing how temperamental those can be we elected not to disturb it.
I can say for certain that my left side rear sidelight thinks it's an indicator and the indicator is having some time off from indicating.
My left indicator bulb had failed to the car, in addition to the indicator also utilised the sidelight as the indicator.
Very clever.
