how to access rear fog light
Dogmatic6
 Glasgow
Hi,
I have a 2006 M. How do you get to the rear fog light? I have removed the access panel and can get to the brake & light bulbs bot not the fog? or reverse I think.
Cheers
If it's the same as an SE, then the whole cluster is attached by 3 nuts under the cover plate inside the boot. Disconnect the wiring and the whole lot comes out, exposing all of the bulb holders. Voila! As I said, that's the case for a mere SE, so can't confirm whether this is of any help to you or not. :?
Cheers.
Cheers.
Thansk for the reply :) there are 3 nuts so I will undo them and remove the unit. My fog light isn't working and has thrown a bulb warning.
