Scooba_Steve said:I wouldn't start and idle it; for 3 months just keep the battery charged up and over inflate the tyres (above normal road but not above their max), unless you will jack it up and rotate them periodically.
srhutch said:Scooba_Steve said:I wouldn't start and idle it; for 3 months just keep the battery charged up and over inflate the tyres (above normal road but not above their max), unless you will jack it up and rotate them periodically.
This, pumping the tyres to around 50psi should do the trick.
G600 said:I really don't think you need to do anything apart from the charger and handbrake, every year I leave a classic parked up (inside admittedly) with 28psi in the tyres and whatever fuel was left in the tank still there, been fine like that every winter for the last decade. As for the cover I'd rather wash it occasionally than risk a cover chaffing the paint in the wind.
