mmm-five said:
If the cars had no HALO device, then it probably wouldn't have 'failed' so much, but then the outcome would have been much worse.
100%, if not for the halo I suspect we would have had a decapitated driver
I saw this image and its astounding that the HALO is still intact
mmm-five said:
Looking at the aerial shots during the red flag, it did seem to me that the barriers came out at a sharper angle, wrong layout than I'd expect.
The section he hit covers what looks like an access road between T3 and T10, I initially thought this might be part of an alternative layout but it doesnt look like thats the case from what I can find online and seeing the road itself its not suitable for that.
brillomaster said:
Part of the problem is that the crash happened in a very strange place - essentially a third of the way down a long straight. all the run off and tecpro barriers are at the corners and braking zones.
Again totally right, just after T3 which is a high speed corner onto a straight, its highly unlikely for crashes to occur there and certainly not at the angles involved in this case, Grosjean hit the barrier at an almost 90 degree angle although his trajectory was more shallow than that.
In terms of the movement just prior to the crash, this video is excellent in terms of looking at the situation as it presented itself and possible reasons for things, personally I don't think Grosjean saw that Kvyat was on his right side, as mentioned in the video the wing mirror probably didnt have visibility of the car or he may have misjudged the distance involved, thinking he had the space. Ultimately only Grosjean can say and thankfully, he can.
[youtube]Y_Gu5WBM3ss[/youtube]
brillomaster said:
thats how i read it... either go left (and off the track) to avoid some slow cars ahead, or go right. there was almost a gap too. some might argue that a better driver would have known what cars were around him and avoided the incident.
I think that's a bit unfair, remember that this all happened across maybe 3 seconds at 140ish mph, the video above goes through possible rationale but as mentioned I'd guess that he didnt see Kvyat and it was a bad racing incident that is a testament to the engineering that goes into safety.
