How do I remove this peice of trim
G-A-R-Y
 North Bristol
My car has Piano Black interior, the lacquer is peeling on the centre console, item No22 in picture. I'm unsure how to fix it but first I need to get it out. Good instructions please.
With great difficulty :D
Seriously, there are guys who had done it and say its a pita - they will hopefully give you some constructive advice :wink:
Do a search on here for centre console removal/wrapping centre console. I removed mine last spring to carbon wrap it. You must remove ALL the centre cubby assembly between the seats starting at the top and working your way down to get access to the lower centre console section. It is quite a straight forward task but it will take you at least a couple of hours to get to the point where you can remove part no.22 which is mounted on the aluminium carrier frame with about million torx screws ! Thankfully it's much quicker to put it all back. :thumbsup:
