How do i remove the front roundel?
You need to remove the kidney grills first. They pull out the front of the car, from corner nearest the roundel if i remember right. You can then get a spanner on the two nuts that hold the roundel on.
All done from the front of the car without opening the bonnet/hood.
Slight correction they come out from holding them near the bottom and pulling
I believe it is 73mm.
When i changed my roundels to carbon fibre one's i just pulled them off. Some needed a little help from a screwdriver.
Miss spent youth perhaps? :poke:
