How do I post a picture with my signature?
You need to use the same coding in your signature that you would in a post.... :thumbsup:
but you will need to do the coding manually... :( or cut and paste... :thumbsup:
For Example... [ img ] http:/ /www.photobucket.com/ youraccount/ yourpic.jpg [ /img ]
Except without the spaces. Just add that to your sig and whola! Just ensure that the pic isn't uber sized please. Short and wide is OK, Like WLH's.
Your image is 235 px high but needs to be no more than 150 px in height....
The height of the picture in my sig is exactly 150 px. If you need help re-sizing the pic let me know.
The coding to display the photo in your sig is as follows:
Code:
[img]http://i1025.photobucket.com/albums/y320/geresey/Apr%2014%20web%20size_zps5zqnrufj.jpg[/img]
and it will display as below:
Code:
Photobucket allows you to edit the picture to the correct px size as above and retain the correct aspect. Check the editing tools menu :thumbsup:
I'm having problems with this too guys. I can get the coding on my signature but the image doesn't appear, what am I doing wrong.
Image might be too big Ray
[XXX]http://i1219.photobucket.com/albums/dd424/RayM49/IMG_0254%202.jpg[XXX]
Replace XXX with
I haven't been able to do this since I started on here. Can't see the edit size function on the app version of photobucket.
Anyhoo just incase someone feels generous I am posting a picture here in the hope someone can do this for me. :D
Got the picture resized on photo bucket I think. 150 height 225 width. No units on photobucket but I assume it is in pixels. It still appears on my sig box as a line of text rather than a picture?
Any other advice, tips? Resized picture shown below with no problem in a thread but not in the sig box.
There is also a file size limit to the picture which is a function of the level of quality. I reduced the file size of your picture to 16 K which is well below the 19K limit I believe. Let me know if you need anymore help.
That's done it. Thanks very much! Only been on a year and could never get it to work.
Thanks again :thumbsup: :D
Replace XXX with
Ok thanks I'll have a go at resizing ta!
I have also been having trouble with this, and my computer-skilled daughter is 100 km away. I just picked a photo and put it into Photobucket, then edited it to resize to 120 px wide. It came out pretty small, but this is a test to see if it shows up as my avatar.
(scan of fifty year old print of my Morgan)
David
Hi, I'm stumped by the resizing hurdle-it keeps asking me to verify it & im clueless?
If I post my signature pic could admin please help me out?
This is the pic I'd like to use,
I'm having trouble too, I'm trying to add text to my signature but it says it can't verify my photo even though it is using it at the moment for all my posts. :thumbsdown:
It says "It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct."
Smartbear said:
That happened to me as well! It sounded so easy...
There is definitely something wrong with signature editing at the moment, you cannot make any changes either to the image or text due to the error you don't get the option to save the changes due to the error message. anybody know how to inform admin?
