How big is your bush.....
LittleZ4
Hopefully this will be a really easy question for you knowledgeable lot.
The lollipops on a 2004 3.0l manual (if that makes a difference). Are they 60mm or 66mm??
I'm about to buy some polybushes as my originals are knackered and I'm unsure of what the size should be??
Any help is greatly appreciated.
I've an '03 plate 3.0 and when I did the same job, research on here suggested all standard pre facelift models were 66mm, sport or not. Its certainly what's on mine.
Thank you!!
I've emailed powerflex as well to see what they come back with. I'll post their response as and when I get it.
So you put 66mm on yours?
I didn't go with poweflex, went with Myle HD standard style but uprated. But I'm pretty sure they were 66mm.
I got my fronts from power flex, rang up, gave the guy my vin number and he sent what I needed. He knew what size anti roll bar bushes were also so I had them as well. No problems with them but this was 3 yrs ago.
I tried ringing but due to everyone being sent home, there was no one there. The email was very non committal
