Hi All
So I use BimmerLink's dashboard to keep an eye on some "gauges" (boost, oil pressure, water pump rpm, battery voltage etc.) and spotted the engine power option. I know the wife's 120d also shows it on her iDrive, but is this actual calculated power (like do they actually run calculations) or is it simply a preconfigured sliding scale (so much throttle, so much rpm should equate to 50% power which in you case is 70Kw)?
Thanks,
R
Thanks,
R
