Hosepipe foam cannon
stevo///m3
 Leeds - you know where it is
I bought a hosepipe foam cannon about two years ago, this one: http://www.cleanyourcar.co.uk/washing-and-drying/cleanyourcar-foam-cannon/prod_1349.html
Since then I've bought a pressure washer and uprated foam cannon so no longer need the above.
It is obviously used but in perfect working order. I think I've used it about 10 times or so. It is certainly not as good as the new foamer I have but it works fine. It is likely to be of interest to those that have a hosepipe but don't have a pressure washer with foamer. The "trigger" section clips directly to your hosepipe with those common connectors you can get at a DIY store.
£35 new so I'm after £15-20 plus postage. If you're local or come to a Yorkshire car meet, very happy to deliver in person (excuse to take the car out!).
Hope this helps someone out.
Stevo
