laurieballard
Bought two replacements from a car being broken on here, hopefully they fix the issue!
Thanks all
Thanks all
laurieballard said:Ha, replaced the callipers and still squealing!!!
Only things left are the handbrake shoes or the slider pins!
It’s weird as hard on braking is ok and light breaking is ok, it only does it at a very specific push down point on the pedal.
Jembo said:laurieballard said:Ha, replaced the callipers and still squealing!!!
From what you’ve done, after the pins & handbrake the only thing left will be to change the car itself
kis said:Really interesting! Hope you do get it sorted! :?
I used red rubber grease on the pins and never had any problems. I can't remember but I'm sure you said you greased all the appropriate areas?
dans6490 said:I had virtually the same issue with my old 2005 X3. I changed the pads and disks to pagid and they squealed under “normal” braking. Under hard braking they didn’t.
I initially thought it was just the new stuff being broken in but after a few thousand miles it was still there.
Cutting a long story short, it turned out to be the discs. After changing the discs to a better brand, the squealing stopped.
From what I had read, I couldn’t see that you had actually replaced the disks, so would definitely be worth doing.
laurieballard said:Ive now replaced the following on the rear:
Pads (three times) - Now Brembo
Discs (twice) - Now Brembo
Calipers
Handbrake shoes - Bosch
Also greased up the slider pins and the normal pad point.
Still squealing.
Im gonna have to sell the car I think, Im not sure what else it could be!
kis said:So would it be advantageous to have a thicker shim? i.e. if the pads have the fixed ant-squeal pad already? (and add more like your link)?
ph001 said:laurieballard said:Anti squeal shims being the ones that come with the pads presumably?
All three sets came with like a metal backing plate which you could clip on or off.
I used this every time including now, unless there is something else you can buy?
Did you even read my post?
road warrior said:ph001 said:laurieballard said:Anti squeal shims being the ones that come with the pads presumably?
oooo 'es a grumpy bugger..![]()
ph001 said:road warrior said:
Just a bit of PMT (pre-masturbation tension). I’m fine now!![]()
