I seem to be having some sort of issue with my horn. One day while driving, I heard what seems like a loose screw moving inside my steering wheel when i turn the steering wheel. Did my usual research on the internet and found out that sometimes there really is a screw that becomes loose inside. So I disconnected the battery and waited a few minutes before I removed the airbag on my steering wheel. No loose screw in sight...turned the wheel thinking it was stuck somewhere but still no screw. So I installed the airbag and connected the battery and inserted key on ignition...the horn just started honking. If I remove key the horn will stop. What gives? Could it be that the screw I heard is now stuck somewhere touching metal making my horn turn on? I had to remove a fuse so I can drive the car...
