High Ratio 3 litre Diff with output flanges for smaller engines cars.
Z4 Racer 19
 Reading-U.K
This is for someone who wants to raise the ratio of their diff so you can reduce the revs needed to achieve the same speed as your current diff. This would be perfect for someone who does a lot of motorway/ dual carriageway driving as this should improve fuel economy as you’ll need less revs to do the same speed you usually would. As the output flanges are the smaller M8 it should fit cars with engines smaller than the 3.0L and this should make this an easy swap. Please ask if you’re unsure as I can help you check to see if it would fit.
This is a diff off a 3.0 litre car with a diff ratio of 3.07 but with the output flanges fitted from a 2.2 litre diff part number 33131428249. I have the diff because I fitted a 2.2 litre diff into my car to help acceleration as it isn’t used anywhere apart from racetracks so fuel economy isn’t an issue.
Feel free to contact me if you have any questions. £195 ONO
It’s fairly heavy so collection only from Wokingham, Berkshire.
