Aebous said:Thork said:Is a quite simple fix actually, the whistle is coming from a crack on the ruber hose for the idle valve on the lower boot that conects the trotle body to the air intake. The part itself is around $50 and it will take no more than 15 min to replace, NOW I got mine replaced under warranty (good will repair ) and for what I got from the tech the new part has been improved. The part is the #5 on the diagram
http://www.realoem.com/bmw/showparts.do?model=BT33&mospid=47798&btnr=13_0995&hg=13&fg=15
I just noticed mine cracked two days ago. I'm ashamed I never noticed it before. I just got the call that my part came in, but I won't be able to pick it up today because I don't have the time. Glad you posted this. If you go take a gander at my thread
http://www.z4-forum.com/forum/viewtopic.php?f=3&t=5592 I posted a pic of the cracked hose. It seems like a straightforward R2 so I'm doing it myself.
Yeap, is exactly the same and is a pretty straightforward replacement, said that, I took mine to the dealer as matter of principle, that piece of rubber shouldn't fail in that way in a car with only 68k miles, and now (from yours and others post) it seems is a common failure
