High motor oil consumption and low coolant
Hi z4 community,
My car started shaking slightly and the rpm meter was going back and forth to small degree when the service engine soon light came on. I ran the obd tool to find that there was misfire in cylinder 3. There was also oil on the spark plug on cylinder 3. I was hoping it was a spark plug or the ignition coil BUT.. when I checked the oil level it was below the minimum line and the coolant was also very low. A little internet research pointed toward the ccv valve and the hoses that connect to it. It looks very oily and the inside has yellowish creamy looking substance :(
I have attached the pictures. I am replacing the ccv components. I also see there is oil on other components, not sure the terms. I also see the engine mount is easily accessible after removing the intake manifold. Any advice is appreciated.
