OK, so firstly this is not an How-To (all being well that'll come later).
So I've wondered about this one for a while now and assumed it would be an expensive mod, with replacement headlights, and probably complicated wiring changes! Well I've been doing a bit of research on it all and it turns out that it's neither.
If I told you that full OEM High Beam Assist (FLA) could be fitted for as little as £35 would you believe me? Well it's true, I've just ordered a used mirror with the same spec as my current one + FLA and the plastic surround (which is bigger than the original one) for £26 complete, to be fair that was a real bargain compared to some out there. All you need to then do is a minor wiring mod from the FZD (the interior light unit) to jumper in the canbus wires (so a bit of twisted wire and some plugs), fit it all up and do a bit of coding, which is basically adding 5AC to the VO and coding that to a few modules. Probably about 1/2 hours work and you've got a new feature on your Z4, for very little money.
This is the mirror with the extra sensor that looks forward...
And this is the replacement surround...
And this is the indication you have on the cluster (not an E89, but it's the same).
This shows that it's in the active state but High Beam is not currently on. Once it turns High Beam on the normal Blue indication illuminates...
And this is what it looks like from outside (again not an E89, but you get the idea)...
So to the best of my knowledge that's it, but according to the options list this was only available if you have auto dimming mirrors.
Also if you have iDrive then you get an option to turn it off in the Lighting Menu.
Like I say though I'll do a proper How-To, including wiring diagrams, photos and full coding process, once I've actually fitted mine.
So, open to discussion, what do you think? Do you already have it?
