Hi all hope someone can assist, I have a 2012 E89 Z4 went to open roof nothing happening just open button on dash flashing red, I have checked the res
cliffy666
New member
Hi all hope someone can help? I went to open the hardtop roof the other day, pressed the open button on dash nothing happened, just switch flashing red, checked the reservoir on hydraulics pump in boot seems ok, I presume there's a wire break somewhere,! can I open the roof manually to gain access to the wiring,? is there a Control module if so where, Ive looked everywhere in the boot but can't find one, HELP Required please
Is the boot partition pulled down and securely clipped in place?
The rooftop control module is located below the floor trim on the right hand side, there are 3 together, one for the roof, one for the parking brake and not sure what the other one is.
  • Like
Reactions: B21
Most hardtops can be opened manually in emergency situations, but it depends on the vehicle.
General Manual Opening Procedure:
Consult your owner's manual – it typically includes a procedure.
Locate the manual release tool – often in the toolkit.
Release hydraulic pressure – some systems have a valve or Allen screw on the pump to do this.
Manually lift the roof – this can be heavy; ideally, two people are needed.
Manually stow the roof – follow the reverse of the normal stow sequence.
Important: Forcibly moving the roof without releasing hydraulic pressure or unlocking mechanical latches can cause serious damage.
