Hey guys,
My zed is running great apart from a slight hesitation at very low revs under load - usually 1-2k rpm and when in a higher gear.
No fault codes come up (although that’s only using cheap scanner) and no warning lights. I’ve also noticed the car popping and crackling a bit more -(not that I’m complaining!) just wondered if it’s all linked - maybe a spark plug not burning fuel properly then dumping into exhaust?
I’ve searched the forum and read about coil plugs etc but without a fault code is there much I can do?
oh and I've cleaned my MAF using electrical contact cleaner and no visible air leaks
I know you guys like pictures so here’s my zed in Pembrokeshire
