Hi Guys,
Not sure if anyone will be able to help me who's come across this before but i've trawled posts for suggestions and can't find anything exactly the same as I am experiencing.
So as I say car hesitates a little and feels like a missfire and or loss of power under mid to hard acceleration and it's audible the whole engine note changes as it happens like you are letting off the gas. It's almost like traction control kicking in but no traction control light and not in situations where wheels would be breaking loose anyway. There are no fault codes logged no EML light nothing to indicate an issue. Car idles well and tootling around you wouldn't know there was a problem at all.
Only recently got the car its an early 3 litre model and i'm going over it and just sorting any issues I find to get it back ship shape again as it needed a little TLC. The car ran fine when i initially got it this seems to have developed after i've done some bits of work on it although I can't see what I could have done to cause the problem if it is indeed me. I have replaced the valve cover gasket as it was leaking oil badly when i got it. I have also replaced the oil filter housing with a new one as that was also leaking badly so alternator and belts and so on will have been off. Other than that new discs, pads, front struts, track rods, air filter, lower arm bushes that's about it before the issues started. Also replaced the CCV system but this was the first job I did and the problem didn't develop until more recently.
I've tried new plugs which seemed to help a little at first but is now back to being as bad as it was before. I've also purchased two new coils and tried them in cylinders 1/2 then 3/4 then 5/6 to see if it helped.. no joy. Plugs 1/2 did look a little sooty (not wet) when i removed them, rest i'd consider normal
It has even been to BMW today for an airbag module replacing (airbag light was only warning light i did have) so I had them update the DME to the latest version in case it was some sort of software bug and if anything it seems to have made the problem worse rather than better (which i'm guessing is more down to the ecu re-learning)
Anyway sort of at my wits end with it i've no idea what to look at next as with no codes I don't really have a whole heap to go on! Any suggestions greatly appreciated. Cheers.
