All help appreciated zed community....
So, on longer journeys, my (yellow) oil light comes on, only when the car gets hot. This began when I replaced my sensor with a non genuine one, as the one in place wasn't working at all. I did replace it with a meyle one (which I'd lead to believe are OEM)???
I left it alone, as I'd just put fresh oil in, but then I got fed up and requested another to check it wasn't faulty.
Then, a few weeks later I discovered I did actually have a leak (oil filter housing gasket), so, I did some research and I have found (I believe) that the orange oil light can be a sign of low oil pressure, which I thought could be it leaking through the gasket.
Tonight, I replaced the gasket and hoped all could be well. A long drive straight after, a nope, it's back.
What else could this be? Could it be that I need a £100 plus BMW sensor? Or is there anything else that could be bringing it on?
I've also replaced the rocker cover gasket in that time to eliminate that.
