Help with springs
Hagar
 Sunderland
Can someone please tell me if all 3.0L e85 roadster have m sport suspension or not. I’ve just bought a pair of suplex springs (part no 06228 ) and now not sure if they the right ones!!!!!!!!
There seem to be lots of Suplex springs. Phone Suplex UK, they will give you good advice.
Be careful with Suplex springs.
I fitted some rears onto my E46 M3 and now my passenger side sits higher than stock ride height.
I don’t know whether this will be an issue on E85 however.
Thanks lads I know one spring is knackered so don’t want to strip it out unless I’ve got the right replacement. Looks like I might have to give suplex w a ring unless someone knows better
Most pre facelift 3.0/3.0i SE cars came with M Sport suspension from the factory, although you could opt for Se suspension if you wanted I've never seen one that did. In fact the only pre facelift 3.0I/SE I know of running SE suspension is mine and that's only because I fitted it.
Post face lift wise 3.0 SE doesn't m sport and the sport does.
You can use one of the online vin checkers to see what yours came with from the factory, it will list which suspension option is fitted.
If you google "suplex catalogue" you should find a link to their pdf which list all the various options. There is a number of choices for the E85/6 varying with engine size, transmission and even options etc
