dbaz193672
Hi
Not long had my 2.5 and it has started to make a 'squeak' noise from what I think is the rear passenger wheel. The squeak quickens as the speed increases so naturally thought it was something in the rear wheel/ brakes etc. the noise goes if the wheel is under lateral load I.e going around a right hand corner. The rear discs didn't look to cleaver so changed the discs and pads but the noise is still there. I have got the 108 split rims on the car and noticed that when the wheel was off the middle part had some slight play in it. Is this right? I have never had split rims before, once bolted on the car there is no movement.
Any help or advice on what to check next would be gratefully appreciated, thanks Dave
