Help with Parts
mark1882
Hi All
Doing some work to smarten My zed up having let my son have it for a year.
The plastic trim ( don’t know what the proper name is)below the windscreen has degraded and started to crack probably due to it being in hot temperatures in Portugal 58F7FD9D-9277-4FEA-8BF2-135769CC0658.jpeg please see the photo. The whippy Ariel broke when I tried to remove properly seized see photoView attachment 1it so need the full unit not just the screw in bit. Looking to replace it with a stubby.
Any advice on part numbers for these 2. Parts and where I can get them from would be appreciated.
Mark
Working backwards on your list:
1. the Stubby - looks like you have enough left sticking out that you could try to get some vice grips (locking pliers/mole grips) after spraying with something to loosen it up. Not sure if WD40 or CRC556 would do the trick? Having trouble finding the part number for the whole assembly on RealOEM (I'm sure it's there somewhere...) but moving onto
2. The 'plastic trim' - I think this is the part number:
Thanks for your info.
Ouch indeed £190 for the plastic scuttle but it had to be done and new aerial base and stubby fitted. Used the stubby from Peugeot perfect fit.
Mark
Mark
What Peugeot stubby? What did you search for?
