Hey,
Was hoping to get some help please with sanity checking myself. My e86 has thrown a check engine light, plugged in my reader and it is showing a 2C9F code for "oxygen sensor heater 2 after catalytic converter: activation".
I thought to have a look at the data for the sensors, to confirm it for myself, and found that bank 2 sensor 2 does seem to be static at 0.43V (no change with rpm), whilst bank 1 sensor 2 rises to 0.73V as the engine gets warm and does fluctuate slightly as it runs. So think that confirms the fault linked to the code.
The main thing I want some help with, though, is that both pre-cat sensors are showing a voltage of ~2V, which from my understanding is way high as they should be 0.2-1V typically. Is it likely that fixing the post cat sensor that has thrown the code will let these drop down?
Never had a sensor issue with this before so not familiar, but the fact it hasn't thrown a code for those seems weird. Any guidance appreciated!
(blips on the graphs below are me taking it up to 3000rpm and then releasing).
