Help with Dice install....
beemer
No, not the fluffy type. (that was an easy job...)
I'm trying to get my head around connecting up a dice mediabridge.
My spec is 04 3.0 with professional sat nav, phone kit, dsp (with coax) but no Cd changer.
Have read pretty much every thread I could find on installing dice, but couldn't find my answer.
The trouble I have is finding the coax and CD changer plug to connect the mediabridge and dsp converter. There is a coax connected to the phone kit, does anyone know if this has to be removed, or should there be another connection hidden away?
Thanks,
Does this help........
http://audiovox.diceelectronics.com/support/avx/support_files/MediaBridge/OMA-MBR-1500-BMW-012012_rev012012.pdf
I'd say you'd been had there Jonny.....
I did have a look at the manual guide AlanJ, but doesn't really say.
I think I've found the 3 pin connector, and I have a coax that runs into BT phone set up.
Just can't find the coax to fit to the DSP convertor, or if I need to disconnect it from the BT phone!?
Thanks,
Lol that's not bad tbh, thought we were still talking the fuzzy variety.... :poke: I'm off in my own little world sometimes.. :rofl:
I had a tonne of trouble installing my Dension Gateway into a car with DSP. In the end SK93 kindly drove over and wired it all into my car for the price of a burger. It might be worth messaging him for some tips, he knew a lot about it! Unfortunately it wasn't simply a matter of plugging in some cables and required some rewiring to get it to work.
Well thought i'd just round this off, ended up being the easiest install ever! Once i'd found the wire.
A little confused about it though, as I have a pre-facelift 54 plate, with DSP, coax connected to amp and phone kit, but still had the 3 and 6 pin CD changer cables, which seems to go against everything else i've read! :?
Pic below shows the 3 and 6 pin connectors and the coax (which was taken out of the phone kit for reference)
