whistlepig33
Ok guys,
Had my Z4 Coupe for 3 weeks now. Absolutely loving it, just two issues I've had, one being the window regulator breaking, thought that's going to be fixed.
When I bought the car, I knew the centre console surround by the gear stick was cracked (where the hazard button is) but its not been an issue up to now. I've been a little over zellous when pressing the unlock door button and due to the cracked plastic I've acidently pushed the button into the centre console, not the whole way, it's pushed in about 5mm. Is there a way I can retrieve these buttons without removing the entire centre console? any special tool or trick? Does the Gear Stick gator remove easily?
If I've not explained myself well, I'll take a photo to explain.
Many thanks in advance.
