Help to choose between 2 Sony Vaio
ksher
Veteran
 Bedfordshire
My old HP laptop is not economically repairable, now I found 2 Sony Vaio. Which one is better for entertainment and gaming?
VPCEE3J0E/BQ
Processor Name: AMD Athlon™ II Dual-Core Processor P340
Processor Speed (GHz): 2.2
L2 Cache (MB): 1
Frontside Bus (MHz): 3200MHz HyperTransport™ 3.0
Number of Cores: 2
Memory Size (GB): 3
Memory Specification: PC3-8500
Memory Speed (MHz): 1066
Memory Type: DDR3 SDRAM
Hard Drive Capacity (GB): 500
Graphic Card Name: ATI Mobility Radeon™ HD 4250 Graphics
Video RAM memory (MB) -
Total Graphics Memory: Approx. 1400MB
Ethernet (RJ-45 Direct Port): YES
Ethernet Type: 10Base-T/100Base-TX/1000Base-T
Wireless LAN: YES
Wireless LAN Type: 802.11 b/g/n
Wireless LAN Max. Date Rate (Mbps):150
Bluetooth: NO
Diagonal Size (in):15.5
Diagonal Size (cm):39.5
Aspect Ratio: Wide(16:9)
Resolution: 1366 x 768
Max Resolution External Display: 1920x1200
VPCEE2S1E/BQ
Processor Name: AMD Phenom™ II Triple-Core Processor P820
Processor Speed (GHz): 1.8
L2/L3 Cache (MB):1.5
Frontside Bus (MHz):3600MHz HyperTransport™ 3.0
Number of Cores: 3
Memory Size (GB):4
Memory Speed (MHz):1066
Memory Type:DDR3 SDRAM
Hard Drive Capacity (GB):320
Graphic Card Name: ATI Mobility Radeon™ HD 5145 Graphics
Video RAM memory (MB):512
Total Graphics Memory:2300MB
Ethernet Type:10Base-T/100Base-TX/1000Base-T
Wireless LAN: YES
Wireless LAN Max. Date Rate (Mbps): 150 (RX)/150 (TX)
Bluetooth: YES
Diagonal Size (in): 15.5
Diagonal Size (cm): 39.5
Aspect Ratio: 16:9
The only online game we play is The Lord of The Rings, not like GT5 or Black Ops, which requires even better graphic. I think second Sony is better because it has 1 extra GB memory, 512MB ATI graphic card, and bluetooth. I'm not sure about the performance of 2 processors. Triple-core processor has slower speed (1.80), but Dual-core processor has higher speed (2.20). But does Triple-core will be still faster because it has more cores? Price difference is only £10.
Your advice will be very appreciated :) . I will be ordering it within 2 days. Thank you.
I would go for the second ...more memory and triple core and bluetooth and looks like separate video card with it's own memory
