Help - Stonechip Repair
Gummi
Hi Everyone, I've got a stone chip on the top of the driver's side wing. There are some microscopic rust spots in the centre, 0.2mm maybe. What's the best way to repair this? I guess remove the rust and then use a touch up kit. I'm not sure of how to remove the rust, scrape it off with a wooden toothpick, rust converter?IMG_20180619_211142.jpg
buzyg said:
Call chips away and get a quote. :wink:
+1 yep I know I'd just never be happy with a touch up pen on that. Have used them for similar chips on cars in the past and have always been surprised; and pleased with the results
if doing DIY:
1) make sure you mask up the area as don't want to make it worse by accidently doing rest of your paint
2) get some rust converter and apply with a very fine paint brush
3) primer
4) sand primer with 1200 grit - best way to do this is get some sand paper onto edge of a pencil (not the lead end)
5) paint (with fine brush)
6) lacquer (with fine brush)
7) sand (2000 grit) until you can't feel the edge of the lacquer.
