Help required.
Update:
New battery required £216.94 for the battery, installation and registration.
Software update £180.
Car wouldn't show faults due to the battery being too far gone.
God knows what else they'll find once the new battery is installed.
RoyArcher said:
Update:
I know garages have to make a profit but almost £400 for a battery (mine cost me £102.34 delivered) and registration/software update really takes the piss, probably less than an hours labour
RoyArcher said:
Update:
Thats why I said find a good indie, take your own battery (£80 to £90) and they will fit it, register it and do the software update- main stealer prices are just crazy.
Software update, plug in laptop, start update, go do another job just keep an eye on the laptop, test-drive, probably 30 mins in total and £180
Wow - that's nuts for a specialist, should not be anywhere near that cost in my opinion.
A battery is nowhere near that even Halfrauds won't charge that to fit and register a battery
A new battery should not cost more than about £125 from somewhere like Tayna Batteries. Add another £25 to code it and job done. Any more than that and he is ripping you off and I would find another Indy. That's almost stealership territory.
That sounds expensive, but does the OP's car have Stop/Start?
Just wondering because when my 1 Series needed a new AGM battery in 2012 Sytner quoted me just over £300 to supply, fit and register a new one. I found an Indy who did it for £254, which still made my eyes water!
RoyArcher said:
My car doesn't have stop/start and he is fitting an AGM battery, whatever that is. 😂😂😂😂
AGM is absorbed glass material - search Tanya which seems to be recommended on here and they are about £125 so £25 for fitting would be reasonable.
I had a battery replaced under warranty on the 335 and my local dealer told me circa £300 - They call it progress !
AGM - Absorbent Glass Mat
From the 'net
While regular lead acid batteries need a topping charge every six months to prevent the buildup of sulfation, AGM batteries are less prone to sulfation and can sit in storage for longer before a charge becomes necessary. The battery stands up well to low temperatures and has a low self-discharge
I suppose it's like any sort of "latest tech" stuff (thinking mobile phones, laptop PCs, flat-screen TVs and even run-flats). Expensive to begin with but as time passes it gets cheaper - thankfully!
Prices are frightening but I would not be happy paying more than £150 for a battery, hell I would change it myself and then its just registering it, no idea how long that takes but ant be that difficult, sure it can be done with Carly
Smartbear said:
Ole gits rule said:
Try Tanya.co.uk just checked for mine and a 95ah AGM battery is £125.00
That’s not the correct battery, you need a 70 or 80ah capacity :thumbsup:
I agree Rob, but that is the one it recommended, did not spend too much time looking for the 80ah version.
Bosch one is only £160
I recently paid under £100 for a replacement oem size agm battery from Tanya.
[/quote]
[/quote]
[/quote]
Thats what I put earlier in the thread that £90 seemed sensible - £216 is a hell of a lot of money and the garage is not playing fair with the OP.
