G-A-R-Y said:I'm at a friends house this weekend, he has INPA, NCS, GT1. I want to code my lights to give audible signal with alarm activation/deactivation.
We don't know how to do it or which program to use.
Any advice welcome.
G-A-R-Y said:Thanks lads, we left it alone. I'll leave it to the experts.
no fit state said:G-A-R-Y said:Thanks lads, we left it alone. I'll leave it to the experts.
Like I said, check out the Carly app. I've coded before with both NCS and SSS and though they get the job done they do need some knowledge and some balls. With the Carly, you just connect, scan for modules, tick want you want to code, code, cycle ignition and you're done. No experts needed![]()
markplant said:no fit state said:G-A-R-Y said:Thanks lads, we left it alone. I'll leave it to the experts.
Is the Carly app as straight forward to use as it seems, an does it work with any odb2 BT adaptor
Coding with SSS is really simple and not the big issue that you are making it out to be!no fit state said:G-A-R-Y said:Thanks lads, we left it alone. I'll leave it to the experts.
Zikim said:Coding with SSS is really simple and not the big issue that you are making it out to be!no fit state said:G-A-R-Y said:Thanks lads, we left it alone. I'll leave it to the experts.
