ga41 said:Guessing he means stability control, on our M's they're both operated together. DSC grabs the brakes accordingly in order to stop excessive understeer or oversteeer hence they can overheat if you constantly drive in a manner that triggers it.
KERMIT1970 said:As i said a few weeks ago ! Have had same problem on my last few Bm's , seized caliper ! No point in cleaning it up slidders etc ! Your only buying time , Get them to change the caliper ! Hope it is covered with your warrenty.
Aliv6 said:But according to the above, they don't sell the kits. It's a new caliper or nowt.
a11y said:Ali, there's something mildly ironic about you owning a French hatchback and a BMW and about which is proving the most reliable...
(yeah yeah I know, stereotypes)
Aliv6 said:So; update, they have adjusted the handbrake slightly. But also are fitting a new OSF calliper...Maybe damaged when it overheated last time around? Warranty picking up the tab fortunately!
Probably for a valetAliv6 said:For sure! Bet they try and charge me for something!
