[HELP needed] Replacing door lock
Hi!
Through the process of resolving locking issue I have replaced passenger side door lock only to find out that the real issue was the GM5 module. After replacing the lock I have found out that doors shut much more quietly. Therefore I decided to replace the driver side lock also. BUT driver's side also has a key lock. Which can be tricky do take out. I've read you need special tools to replace the lock. Did anyone tried this yet? Is there maybe some picture guides?
Thank you very many much :)
