Help need pinout for convertible module
Thanks for your follow up.When you have a chance could you do a write up on taking the top off asthis would help us lesser mortals. :thumbsup:
kunta said:
hello.....
How exactly did you locate the disconnection location in the wire
t.you
There are basically four major bends the tighter ones are under the glass top, I will post some pics of putting it back on... six torx (they are super tight and if you use the wrong torx they will strip) and you can get to them with out removing the head liner... but basically six torx and you are there, cut close to plugs soldier run to the end of the second bends with nice flexible silicon wire and you are done, there are only 3 pairs that need replacing, two on passenger one driver. The picture I posted show locations of damage areas, the other wires in the lower bend where not broken but getting close to breaking
Red wire looks nice with my interior, haha 18g is really nice 20g May be too thin but it’s up to the person.. the silicon is super bendy and hopefully will last the rest of this cars life.... you cannot turn that holder up the top hits it, so had to turn it back the way it was, super happy the way it looks and turned out, I will be adding more tie wraps as it does rub on the sides and the defroster wire was showing metal which is why I added shrink tube
This is final outcome, works perfect looks cool.... no issues if you have any questions I am glad to answer, I think it is pretty straight forward....
