Right heres the deal, I installed the One Touch Module, and the passenger window stopped functioning correctly, was told I could have a bad connection, I repaired the connections and everything seemed fine, so i put the roof down, and it wouldnt come back up, it was as if the botton was disabled!
So I've removed the module...and everything is working fine, windows auto up, down, roof opening and closing...
As the moment the wires are still ready for plugging straight back into the module, all i've done is unplugged it and wrapped insulation tape round the connectors to the module sockets...
Anyways, just been outside and plugged everything back into the module...windows are working, and the roof came down without an issue...
Then when it came to putting the roof back up nothing happened, the button didnt light up, nothing came from the motors...nothing...
So i removed the module, taped everything back up, and everythings back to stock and working! Any ideas? is the module just broken?!
Heres an idea of how the module is connected...
Each wire from the car or plugs are connected to something like scotch lock, its the block things which have screws, dont know what you call them...This is in turn connected to a piece of wire on the other side which has the connectors to the module connected to it! Once I unplug the module i simply tape the applicable cables together to retest and everything is fine, however, when I plug the module back the roof wont come back up!
