kis said:Z4M-2006 said:If i was to look at it without knowing any history,i would have put money on it being damage from a high speed lock up.
But then you'd get two 'matching' marks on the two front tyres?
If one wheel locked enough to do that damage and not the other, the car would have pulled to one side like a pig :|Z4M-2006 said:kis said:Z4M-2006 said:If i was to look at it without knowing any history,i would have put money on it being damage from a high speed lock up.
Not necessarily.
exdos said:Stigbew,
If I were you, I'd take that tyre back to the supplier along with your receipt and make a complaint against the manufacturer. That tyre doesn't look as though it's been gnawed by any form of rodent, nor does it look as though it's been in a lock up. There is no evidence of directional "smearing" that would've occurred if the damage had been caused by braking.The rubber looks as though its just softened and merged the blocks in the tread on one patch of the tyre as if that section of rubber has not set properly when the tyre was manufactured.
john-e89 said:Two thousand miles of wear says they’ll laugh him off the phone id think....you’ve locked up and worn a patch sir....prove you haven’t....goodbye.
