Help identifying Click noise over bumps
GreySquirrel
 Torquay
I have been trying to find the source of a clicking noise that I am getting from my car when going over speed bumps or uneven surfaces. It is a short sharp click that happens when the suspension loads up again after coming off a bump. It seems to be mainly coming from the rear right wheel area, but when driving it sometimes sounds like it is the front, or even the left rear.
Before it started, I changed the rear shocks, but I have checked all the mountings, and they are fine. I also put new ARB droplinks on the front and back, as I thought that's what it was, but there was no change. I replaced the rear ARB bushes at the same time.
I got my son to drive over a plank of wood while I listened to it from next to the back wheel, and it is definitely coming from the wheel area. Bouncing the car doesn't replicate it.
It doesn't sound bad, but it's loud enough to be annoying. Any ideas appreciated!
I have a similar issue and there’s also this recent thread…
Yes, I've seen that one before, and reading it again, it makes a lot of sense. Maybe I will give that a try; it seems a little counterintuitive to drill the metal sleeves in a top mount, but I can see how it may allow the shock to tighten up more and take out any free play that could cause the click noise.
It really does sound like it's coming from the wheel, though! Wouldn't the noise from a top mount be centred around the top mount area? This noise is only apparent with the roof down.
