cheers is there not a rubber part to the mount as well that could need changing cheersAndyBeech said:You don’t need the whole top mount assembly unless it’s damaged which is highly unlikely. Just the bearing is fine, part number: 31331090612
It should only be around £20 each, I wouldn’t bother getting a different make even if it’s possible with that part, just go OE.
maddstaff said:cheers is there not a rubber part to the mount as well that could need changing cheersAndyBeech said:You don’t need the whole top mount assembly unless it’s damaged which is highly unlikely. Just the bearing is fine, part number: 31331090612
maddstaff said:cheers ive ordered 2x that part from bmw, and they have also sold me some spring part as well to go with this, still not half the price of two new mounts thou so thankyou
maupineda said:it can happen, see this. I changed them, but if the rubber looks good, you can reuse. I would change them though
https://www.e90post.com/forums/showthread.php?p=19544730
