charlieaf92
I have an 03 3.0i that I purchased about 6 months ago (it has 62k miles). I've noticed a tapping/ticking at idle since I bought the car (I am assuming it does it all the time, but it is only audible from outside the car, so I only hear it at idle). Sometimes it seems to be louder than other times.
I did some research and read about the VANOS causing a similar issue - but since its done it the entire time I've owned the car I can't speak to any loss of low or high end power.
It seems to run and idle great and there are no check engine codes. From a power standpoint, it does seem to be lacking in the mid to upper range. It seems like all of the power is right around 3k and everything else is just sucking wind. But, again I don't have anything to compare it to and my previous car had about 50 more hp and a vicious power band that would snap your head back when you hit 5,000rpm.
I am wondering if there are any tricks to verifying if the VANOS is bad other than taking it apart? I may get a stethoscope to try to narrow down where the ticking is coming from - but it seems to be coming from the front of the engine so it leads me to believe its VANOS related or a bearing/pulley going bad.
Here is a quick video I took today - it is hard to distinguish the noise over the normal engine noise, but if you listen closely you can hear it when I put the camera in close.
[youtube]http://www.youtube.com/watch?v=6NrKAwLAuE8[/youtube]
Thank you!
Charlie
Thank you!
Charlie
