Help - Bonnet not opening
Machpb
 West Sussex
Hi guys,
Stuck with a little problem, I am unable to unlatch my bonnet to open it up to top up the oil.
The bonnet release in the cabin simply has no resistance and doesn’t feel normal, which I think may mean that the cable may have snapped?
I’ve tried pulling the latch and carefully pushing down on the bonnet with no luck!
Any ideas? I need to get the bonnet open to add oil after the top up warning came on and I commute a fair few miles per week.
It’s a 2006 BMW E85 3.0
Any help would be greatly appreciated.
As above, lift grille and pull bottom forward. You'll then be able to operate the cam to release it with a long screwdriver.
There is a plastic joint just behind the drivers headlight that falls to pieces and stops the handle working.
Mike
Thanks chaps for your advice! I've managed to finally get the bonnet open by accessing the cable through the wheel arch.
However, I am now unable to close my bonnet properly, it just won't latch as it normally would. Has anyone come across a remedy for this by any chance?
f**k me i cannot for the life of me get mine open,
went through the grilles pulled the cable and can feel the wee "cog" that must move back to let the loop on the bonnet pop up past it, but it is not budging at all
with a long screw driver do you go up through where the cable feeds in or are you come from the opposite side ? my latch is not like this one
like this
it's a vertical cable and spun 90degrees clockwise
edit > changed the bottom picture, maybe can go vertically up the left hand side oft hat and catch the clip not much to hit though
I think you can pop the 2 catches from the bulb replacement panels.. I'm sure I've popped mine by accident when messing around.. once they're released just open the usual way? - aka using you hand to pull the latch in the center open.
I had this last summer in my 2003. It took 3 days of spraying down with WD40 until it released. Once open i striped it down and cleaned it up, no trouble since then.
