Hi,
I also posted this on the problems forum in response to the DSC query on there:
I’m new to this forum. I’ve got an ‘05 E85 3.0 litre roadster, which I bought in march/april. Love the car. I’ve only ever run crap sensible repmobile family type stuff, getting my speed kicks from my bike, but this car is a lot of fun on four wheels for sure.
Anyhow, i’ve very recently suffered from the dreaded DSC lights, and did a lot of searching for information on the interweb. There’s a lot out there but some of it is confusing and contradictory, so I thought I’d share what I found out on here. BTW, I’m not saying that the following is correct, so please feel free to disagree.
Fortunately for me, my problem turned out to be a failed pressure sensor on the brake master cylinder. I took my car to a local performance car specialist for diagnosis and repair (replacement of sensor), and the total cost was about £230 all-in.
From my internet trawl, my understanding is that certain DSC units can be repaired and certain units cannot. I believe the one fitted to my car is a Continental Teves Mk. 60 DSC unit which almost everything I found says cannot be repaired. During the last couple of weeks I have been in touch with a company called sinspeed (e-mail:
[email protected]). They also have a website. They reckon that they could supply a replacement hydraulic unit for my car for £240 + VAT with lifetime warranty. I quizzed them on this, bearing in mind everything I’ve read, but they assured me it was good for my particular model of Z4. The words they used in their last e-mail were:
“We are supplying the hydraulic valve block with a modified pressure sensor, it is uprated to withstand better pressure and will not over pressurise which is the design fault in your original unit. I can confirm it is the correct part for your vehicle”.
The preceding e-mail response to my initial enquiry said:
“This is a very common fault and we now carry these units in stock, on the shelf & ready for dispatch. These units now come with our full Lifetime warranty and are self-calibrating, making them fully plug & play. - This means no programming will be required. Literally just remove your unit from the vehicle, fit our modified unit which is a direct fit part and bleed the brakes, upon a test drive the lights will automatically go out as the unit self-calibrates back to the vehicle. You will still have full functionality of the ABS / ESP system as before”.
Obviously I have not tested these claims and cannot verify if they are true (maybe someone on here knows more about sinspeed?), but I guess it’s worth getting in touch with this outfit and seeing if they can supply what they say. It’s gotta be better than being screwed by BMW for a new DSC unit (if it all works as advertised of course).
Cheers,
Garry.
