Help A559 code
sumotan
Hi Gents
Advice pls on occasion I have this code appear.
Seems to point to a relay, where is this located ?
there are some results on here about it too if you search. but not relay. possibly battery (you been driving it much lately) ?
https://www.m3post.com/forums/showthread.php?t=933919
Thank Clark yes been driving the car . Did google & see that its battery drain/ charge issue but no error signs appears on the Cluster etc. Do wonder if IBS is faulty.
Many Thanks
Think i remember seeing this one as well as a few others on mine first time i did a full scan, cleared all the codes after a battery replacement and its not been back since
First time i plugged in my Foxwell reader i saw this, i just assumed it had something to do with the battery replacement a year or so before.
Cleared and never seen again, although do have a re-occurring ABS fault code, doesn't come up on dash though.
Many Thanks
How old is your battery? :?
Thanks Gents
Hi Smart Bear if you recall I had a overnight flat battery, found out battery faulty replaced a new which was about 2 weeks ago & had use my scanner to register the new batt. Seen this a couple of times under instrument cluster when I scan. Do wonder if it drains battery as well.
Cheers
