Hello
Metaalicwolf205
New member
Looking for some help on a problem I’m having but wanted to say hi first
Hi!
Nice motor you have there.
The road is dry and the roof is up so my guess is you're going to ask about roof issues. :D
Or possibly how to fit a new front lower grille? :poke: :wink:
I wish
It’s got a secondary air pump that’s going out and is giving a p0171 p0174 and p0430 error when I check it not sure if replacing that will fix it but I’m hoping someone knows something.
Hopefully someone will be able to give you some advice about your problem.
Welcome along- as I posted on your other thread I would check the air intake boot to see if it has a split on the small pipe that comes off it- common fault that can throw lean codes- see here for what to look for.
https://z4-forum.com/forum/viewtopic.php?t=70223
In relation to the secondary air intake we didn’t get the. In the UK so a more American forum may help with that. It may be possible to remove it all together?
