Ghila36 said:
Hello new member from the north east photos to follow.
If your motor is operating in that upright position then you have enough fluid in there to cover all the ports.
Rather than just 'hear a motor running' get someone to operate it while you hold the motor. You'll soon know if its running.
If it is, swap the electrical connections in case its running the wrong way round.
Then pull the screwdriver out, remove the plastic housing and see if the brass plunger will move out. It only moves a few mm. Could be seized in.
If you find the motor is running and the plunger is definitely pulled out, then you are looking at a new pump. That is the top square part in your picture.
If you say that removing the screwdriver stops it being able to move manually then it suggests the plunger is moving and you are then trying to force it against a hydraulic lock. Don't try to hard or you'll burst a pipe.
I'm leaning towards a new pump tbh.
