Maniac said:It’s heavy because it’s part of the roof mechanism. I use the badge to open the lock and then lift the boot itself by its lower edge.
Why should I do that, I can pump iron opening my boot for freePlayer 1 said:I think someone ought to pay the gym a visit![]()
Mine doesn't exactly squeak but the motor on mine makes a noise as it shuts the boot lid down tight, also makes the same noise upon opening as it releases. Could this be what you are hearing?BeardyJon said:Speaking of boot lids... does anyone else squeak quite loudly when it sets down after opening or closing the roof? I can't work out exactly where the squeak is coming from and would like to eliminate it.
eff1guy said:Mine doesn't exactly squeak but the motor on mine makes a noise as it shuts the boot lid down tight, also makes the same noise upon opening as it releases. Could this be what you are hearing?BeardyJon said:Speaking of boot lids... does anyone else squeak quite loudly when it sets down after opening or closing the roof? I can't work out exactly where the squeak is coming from and would like to eliminate it.
BeardyJon said:eff1guy said:Mine doesn't exactly squeak but the motor on mine makes a noise as it shuts the boot lid down tight, also makes the same noise upon opening as it releases. Could this be what you are hearing?BeardyJon said:Speaking of boot lids... does anyone else squeak quite loudly when it sets down after opening or closing the roof? I can't work out exactly where the squeak is coming from and would like to eliminate it.
I don't think it's the motor. I guess it's more of a creak than a squeak... lower pitch... similar to a creaky floorboard. I don't think it did it when I first bought the car. Maybe its the cold?
ihadablackdog said:BeardyJon said:eff1guy said:Mine doesn't exactly squeak but the motor on mine makes a noise as it shuts the boot lid down tight, also makes the same noise upon opening as it releases. Could this be what you are hearing?
I had this and Biggles told me the solution!
Read this https://z4-forum.com/forum/viewtopic.php?p=1528918#p1528918
Fixed it for me first time!
