Nota TR5 man
Ok Zedites do any of you have any idea why or how I can fix my heater that only works on offside on my 2004 Z4 3.0i. The screen demist and passenger outlets all fail to give heat but are blowing air.
Thank you for this sad news that seems to be an awful job to cure. I will wait until I get the urge to sort the damn thing. At least the fan works well and I have lived with it for 3 years+. I was hoping that its just some piece of trim that blocks the heat.Street said:Bad news I’m afraid. It’s almost certainly a clogged heater matrix under the dash from my experience.
You can start by trying to rinse out the matrix with simple hose pipe. I’ve had some success to improve some over the years by running central heating cleaner through it over night using a water pump. Most extreme is a matrix replacement and it’s probably the most intrusive job of any. A full dash out job![]()
You can try disconnecting the hoses at the bulkhead and flushing back and forth until you get bored. That 'may' shift some crud but not a complete cure.Nota TR5 man said:Thank you for this sad news that seems to be an awful job to cure. I will wait until I get the urge to sort the damn thing. At least the fan works well and I have lived with it for 3 years+. I was hoping that its just some piece of trim that blocks the heat.Street said:Bad news I’m afraid. It’s almost certainly a clogged heater matrix under the dash from my experience.
Indeed the fan blows so it will poorly demist in most instances and in truth it was only the wife complaining that her side was cold that I noticed.McSwerve said:Mine is a similar age and has the same problem.
I’ve never investigated, but probably should do.
Is there a fan blowing air to the near side, but it’s just not hot?
Be warned that even when you've got it out of the car it still isn't all that easy to get the matrix out.Nota TR5 man said:Thanks for the input guys I will wait until I feel the urge to fix it!
