Been having problems with my heater ever since fitting facelift heater controls to my pre-facelift Z4.
Basically, when i originally fitted the facelift controls, nothing worked, so i fitted the facelift controls with the pre-facelift circuit board (innards).
After that, all the buttons and dials light up, but it just blows cold air out the vents. The only way i can get heat is by using the 'hurricane' button in the middle of the airflow direction dial. This sends a huge mass of air towards the windscreen, but at least it's hot!
Tonight, i decided to remove it all again and have a look what the problem is. No matter what i do, i can't seem to get the airflow direction dial to physically change the airflow, even though the dial turns perfectly fine.
I plugged in the laptop and had a look at any errors stored and found this one in INPA. As soon as i clear the error, it comes straight back, so theres obviously a problem somewhere. A rough translation gives me something along the lines of potentiometer short circuit.
Any ideas? I tried to find out whether it was in transport mode, but i don't think you can on INPA. I tried using DIS but couldn't seem to get it working for some reason.
Next step is to buy another pre-facelift heater control unit and see what happens.
