heated seats
mr.tourette
Veteran
 north wales
Not sure if my car has a thermostat issue or "theyre all like that guvnor" but no matter which setting mine is on it seems the same... which is pretty hot to the point i have to turn it off, other cars I've had its been pretty noticeable between low and high settings and you can do the whole journey on low setting...thoughts?
Have you tried both seats to see if they both do the same, or if you can notice difference on other seat, not an issue I've seen a post about before, if you know another zed owner with heated seats ask if you can swap switch panel out to see if that cures it,
I keep meaning to try the passenger seat out, i would go out and do it now but have dropped it off this morning for a new sports exhaust and wont have it back till Monday night, Its not really a big deal as I dont use them much but I was just curious if anyone else had noticed not much difference in the settings.
Why not put a thermometer on the seat under a towel perhaps. Then try settings 1,2 and 3 on each seat and make a note of the temperatures. It may help to confirm if they are working correctly or not.
Hi mr Tourette, I've got heated seats & like you I don't use them often, I'm pretty sure there's a noticeable difference between max/min though.
Regards
hmmm... no thermometers im afraid...thanks for the suggestion andysat, while I'm sure they're in plentiful supply in your gaff i don't own one and I'm not sure i want to borrow one from your well worn supply :lol: :lol:
