Heated seat lights
olsonn
I know that somebody has already raised the issue of one of there seats not working, the light came on when pressed but then went straight out again. I am having a similar problem, but it is affecting both seats, I press the button to turn each one on in turn, the light comes on for a second and then goes out. When I try it a second time the light fails to illuminate at all, any suggestions greatly appreciated
Having had a look at the diagram I would check the 25A fuse numbered F15 first. Hopefully it’s dead and you can replace and monitor.
