Heat shield removal
Osprey6010
 Birmingham - England
Trying to remove the heat shield just below the drive shaft. This mounting plate is just below this shield, is it OK to move? It looks like it should be holding something heavy.
It's the bolts that hold to the exhaust mount rubbers that you'll likely struggle with.
The rubber mounts will twist before the corrosion let's go.
The rubber mounted nuts are much, much easier to undo with an impact driver. Doing it by hand is usually very frustrating - as you're just fighting the rubber's desire to twist
